This action reorders a procedure group by assigning a new order number to an element of the procedure group.
swlibrary action=repositionItem name=procedure_group_name
procedure=procedure_name item=item_name version=item_version position=new_position
Specifies the name of the item where the procedure is located.
Specifies the name of the procedure group to be reordered.
Specifies the new position of the procedure.
The position has to be greater than zero and should not exceed the number of procedures in the procedure group.
Specifies the name of a procedure which will be repositioned.
Specifies the version of the item where the procedure is located.
