This action modifies target computer attributes.
targetcomputer action=modify name=computer_name
[address=network_address]
[calendarname=calendar_name]
[user=user_name]
[phone=phone]
[location=location]
[comment=comment]
[softwareManagedSystem={y|n}]
[racpolicy={automatic|common|deferred|disabled}]
[downloadMethod={NOS|NOSLESS|DTS}]
Specifies the network address.
This entry should not be the empty string.
Specifies the name of the calendar that drives the activities at the target computer
Note: If an empty string is entered no calendar is assumed any longer.
Specifies a comment.
If an empty string is entered, no comment is assumed any longer.
Optional parameter.
If coded the download method of the addressed target system is switched as follows:
NOS |
"Internal - NOS" |
NOSLESS |
"Internal - NOS-less" |
DTS |
"DTS - NOS-less" |
If not coded the download method remains unchanged.
Specifies the location of the computer.
If an empty string is entered, no location is assumed any longer.
Specifies the name of the target to be modified.
Specifies the phone number or email address of the user. If an empty string is entered, no phone number or email address is assumed any longer.
Optional parameter which specifies the Reinstall after Crash (RAC) policy of the system.
The following values can be used:
The common policy will be used for this computer.
RAC is disabled on this computer. No job container is set up for this computer. However, its installation records in the installations folder on the SD server will be marked as removed, when the SD agent of the computer reports a new OS installation (by a changed UUID).
A RAC job container will be created. It can be reviewed and modified, since it has to be activated manually.
A RAC job container will be created and activated, starting the delivery of job orders to the computer.
Default = common.
Note: If you try to change the RAC policy of a computer when it is in the offline mode, the cadsmcmd targetComputer action=modify command generates an error message.
If softwareManagedSystem=y, then the system is considered as a Software Managed System. If softwareManagedSystem=n, then it is considered to be not a Software Managed System anymore.
Specifies the name of the user.
If an empty string is entered, no user name entry is assumed any longer.
Note: If a parameter is not coded, the related target computer attribute remains unchanged.
