This action removes a job, identified by item, version, and procedure, from the software template.
templategroup action=removeitem
name=template_group_name [swTemplate=software_template_name] item=item_name version=item_version procedure=procedure_name
Specifies the name of the item addressed by the job to be removed.
Specifies the template group name.
The name of the procedure specified in the job to be removed.
Specifies the name of the software template from which the item will be removed.
If not coded the default name “<group name> [$date $time]” is taken.
Specifies the version of the item addressed by the job to be removed.
