This action shows the attributes of a job assigned to a software template.
templategroup action showAttrItem
name=template_group_name [swTemplate=software_template_name] jobName=name_of_the_item_order
Specifies the name of the item order to be shown.
Specifies the name of the software template, which contains the item order to be shown.
Specifies the name of the software template where the job to be shown is located.
If not coded the default name “<group name> [$date $time]” is taken.
Consider to be shown the assigned uninstallation job shown previously. The following command will provide the required information:
cadsmcmd templateGroup action=showAttrItem name=tg swTemplate=tg jobName="prod 1.0/00:unist"
CA IT Client Manager r12 ITCM Command Line Version 12.8.0.xxxx Copyright (c) 2013 CA. All rights reserved. Trace mode: Off Connecting to manager "<default manager>" as user "<default user>" ... ok. Manager: mymanager Domain: mydomain Domain type: Domain Supporting: CO CCNF USD OSIM ------------------------------------------------------------------------------- Show attributes of the assigned job "prod 1.0/00:uninst" ........from the template group "tg" ------------------------------------------------------------------------------- Job name...............................: prod 1.0/00:uninst ..Item name............................: prod ..Item version.........................: 1.0/00 ..Item type............................: SOFTWARE ..Procedure name.......................: uninst ..Delivery calendar....................: ..Timeout <days/hours>.................: 7 / 0 ..Job startup..........................: local time/exact ..Pre action............................: no action ..Post action...........................: no action ..Job operation mask...................: 0 .........................................ignore calendars on target computers ..User parameters......................: ..Prompt timeout <days/hours>..........: 1 / 0 ..Job task.............................: 2 - uninstall SDCMD<A000000>: OK
