This action allows you to list the renewals related with a job container.
jobContainer action=listRenewals
name=job_container_name
[{filter=filter|filterfile=file_name}]
Specifies the name of the job container and the renewals to be listed.
Specifies the expression to confine the amount of information listed.
The attributes for building filter atomic expressions is listed under the section list.
Specifies the name of the file that contains the filter commands.
The commands in the file are specified in the same way as in the filter parameter, but the size of the file is limited by the capacity of the system that runs this command..
