Previous Topic: ExampleNext Topic: Example
list—List Computer Groups
This action allows you to list all computer groups including query groups and software templates.
compgroup action=list
{filter=filter |filterfile=file_name}
filter
Specifies the expression to confine the amount of information listed
Computer group name
string
Group type
{Group | Query[/Template] group | Template group}
Scope
string
Comment
string
Creation date
Date
Creation time
Time
Change date
Date
Change time
Time
Query
string
query groups only
filterfile
Specifies the name of the file that contains the filter commands.
The commands in the file are specified in the same way as in the filter parameter, but the size of the file is limited by the capacity of the system that runs this command.
