Previous Topic: Distributed Software ManagementNext Topic: Example
listDistSW—List Distributed Software Products
This action lists all software products distributed to a CA ITCM domain. To limit the amount of information you can specify a filter.
area action=listDistSW name=area_name
[{filter=filter|filterfile=file_name}]
name
Specifies the name of a CA ITCM domain. For it the distributed software will be listed.
filter
Specifies an expression to confine the amount of information listed
The following attributes are valid to build atomic filter expressions:
Attribute
Type
Item name
String
Item version
String
filterfile
Specifies the name of the file that contains the filter commands.
The commands in the file are specified in the same way as in the filter parameter, but the size of the file is limited by the capacity of the system that runs this command.
