This action lists all CA ITCM domains. To confine the amount of information a filter can be specified.
area action=list
[{filter=filter|filterfile=file_name}]
Specifies an expression to confine the amount of information listed
The following attributes are valid to build atomic filter expressions:
Attribute |
Type |
Area |
String |
Host name |
String |
Registered at |
String |
Last Modified at |
String |
Comment |
String |
Version |
String |
Specifies the name of the file that contains the filter commands.
The commands in the file are specified in the same way as in the filter parameter, but the size of the file is limited by the capacity of the system that runs this command.
This section contains the following topics:
