Previous Topic: Set Values (Table)Next Topic: Rule Results/<rule id>/Idents (Optional Table)
Rule Results/<rule id> (Group)
The Rule Results/rule id group contains the following information about the groups created for each rule that is selected during the test:
Attribute
Type
Description
Idref
string
Specifies the name of the fact (a URL)
Role
string
Time
string
Specifies the time when the result was generated
Severity
string
Version
string
Weight
double
Specifies the weight of the result in the weighted scoring models
Result
string
Specifies the result such as, "pass", "fail", "error", "unknown", "notchecked" or "notapplicable"
