After the compliance check, the scanner reports the following results for each rule in the XCCDF file:
Indicates that the computer has passed the compliance check for the selected rule.
Indicates that the computer has failed the compliance check for the selected rule.
Indicates that there was an error while performing the compliance check for the selected rule.
Indicates that the rule does not contain a check defined, making it impossible for the scanner to perform a compliance check for it.
Indicates that the characteristics being evaluated cannot be found or the characteristics can be found but collected object flag is "not collected".
Indicates that the rule is not applicable to the operating environment installed on the agent computer.
