You can create queries or reports based on the results produced by DCS, just as you do with any other inventory data. For more information on queries and reports, see the DSM Explorer online help and DSM Reporter online help.
The DSM Reporter provides the following CA ITCM Release 12.8 predefined report templates for DCS scan results:
Reports the summary of the scan results for each computer in the domain manager.
Reports flat score results for each computer in the domain manager.
Reports the scan results for all the rules in a checklist for a particular computer. This report invokes a runtime query that lets you filter the computers for which you want to view the rule results overview.
Reports the scan result for all the patches in a checklist for a particular computer. This report invokes a runtime query that lets you filter the computers for which you want to view the patch results overview.
Reports the details of the input files (SCAP data stream) used in a particular computer for DCS scan. This report invokes a runtime query that lets you filter the computers for which you want to view the input files information.
Reports the details of the result files produced by DCS scan on a particular computer. This report invokes a runtime query that lets you filter the computers for which you want to view the output files information.
DCS logs are added to the following log files on the agent computer:
Contains the logs related to compression and decompression of the checklist files, creation and verification of the signatures for the checklist files, and the actual checklist processing.
Contains the logs related to the transfer of checklist files and result files to and from the agent.
On the Manager, DCS scanner logs are added to the following file:
Contains the logs related to the transfer of XCCDF result files, OVAL result files, and compressed checklist files to and from the DSM engine.
The log files are available under ITCM_installpath\logs directory. Apart from these logs, the scanner also saves the output of running the OVAL interpreter for each OVAL file in an ovalfilename-ovaldi-stdout.txt file under the checklist output directory on the agent computer.
