The Non Resident Inventory policy group lets you view or edit the existing configuration policy parameters that control the behavior of the NRI Web Service. You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog.
Specifies whether or not the NRI Web Service should copy the received inventory reports to the local Asset Collector. If enabled, the files are placed in the first configured collection folder of the Asset Collector. Valid values are as follows: 1 = enabled and 0 = disabled.
Default: 1
Important! If the collection folder is different from the default collection folder (that is, AssetCollectorCollect relative to the DSMROOT folder, c:\program files\ca\dsm), then this folder must be fully accessible by the Internet Guest Account, which must be set up manually by the user.
Specifies whether or not the NRI Web Service removes the files from the received inventory folder after it has copied them to the Asset Collector folder. This policy is only acknowledged if the Copy files to Asset Collector policy is set to 1. Valid values are as follows: 1 = enabled and 0 = disabled.
Default: 0
Indicates whether or not the NRI Web Service should accept a file download or inventory upload request. Valid values are as follows: 1 = enabled and 0 = disabled.
Default: 1
Specifies where the NRI Web Service should place the received inventory reports. Unless the folder is fully qualified, it is placed relative to the DSMROOT folder, for example, c:\program files\ca\dsm.
Default: NRIReceivedReports
Important! If the default value is changed to a different folder, then this folder must be fully accessible by the Internet Guest Account, which must be set up manually by the user.
