There are two prerequisites that must be met to enable the UAMhmcConfig script and the asset management agent to run remote commands on the HMC:
Note: SSH is supplied with the AIX operating system but not installed by default.
Note: For Windows agents, the Plink (PuTTY Link) utility is installed with the agent, providing an SSH command line interface. See the Configuring Plink on a Windows Remote Agent Host section for details. The commands for configuring the Windows agent described later in this section may also work with any other SSH command tool that you might already have.
