Previous Topic: Restrictions and LimitationsNext Topic: UUID Generator for Agent Bridge
Agent Bridge
The Agent Bridge is a CA ITCM enhancement that provides backwards compatibility for extended and legacy agents based on the current version of CA ITCM. You can gather information obtained from mobile agents and then distribute jobs, modules, templates, and configurations to those agents.
Note: The Agent Bridge is supported on Microsoft Windows only.
Note: The agent platforms supported by the Agent Bridge in this release are Windows Mobile 6.1 (ARM-based, including StrongARM, XScale), Windows Mobile 6 (Classic, Standard, Professional) (ARM-based, including StrongARM, XScale, TI OMAP), and Windows Mobile 5 (ARM-based, including StrongARM, XScale).
Major Components
The Agent Bridge consists of the following components:
Note: Asset management and software delivery legacy agents installed on the same machine should point to the same CA ITCM Release 12.8 scalability server with Agent Bridge enabled.
