Use the "setupplatform -p network" command to enable SSH from the platform shell as follows:
schostname:SC> setupplatform -p network
Network Configuration
Is the system controller on a network? [yes]:
Use DHCP or static network settings? [static]:
Hostname [schostname]:
IP Address [xx.x.xx.xx]:
Netmask [xxx.xxx.xxx.x]:
Gateway [xx.x.xx.x]:
DNS Domain [xxxx.xxx.xxx]:
Primary DNS Server [xxx.xxx.xxx.xx]:
Secondary DNS Server [xxx.xxx.xx.x]:
