Previous Topic: The NRI AgentNext Topic: Script File
Command Line
The following table lists the command line switches that the NRI agent recognizes:
Command
Description
-o “<output path>”
Specifies the location where the agent should put the inventory XML file.
-origin “wished origin”
Specifies the origin of the asset. See the Asset Collector documentation for more information on origin.
-trustlevel <trustlevel>
Specifies the trust level of the asset. The trust level can be a number between 1 and 5. See the Asset Collector documentation for more information on trust level.
-file “[set the File Name variable]”
The output file is by default named using the generated host UUID. This can be overridden through this parameter.
-nohw
Do not collect hardware inventory.
-nosw
Do not collect software inventory.
-script <script file>
Location of script file.
