Control of software inventory scanning is done in the Software section of the script file.
Example: Software Section
[Software] Method=0/1/2
ScanRestrictedUser=0/1
The following table includes the parameters available in the Software section:
Parameter |
Description |
Method |
Specifies which software scanning method to use. The value can be one of the following: 0 = No software scan is performed. 1 = Runs the heuristic scanner which scans the MSI and Add/Remove database. 2 = Runs the Signature Scanner which uses the CA provided signature database to recognize software. |
ScanRestrictedUser |
Indicates if software inventory scanning should be performed for restricted users. 0 = No. Restricted users are not scanned. 1 = Yes (default) |
