Symptom:
I need to verify that Agent Bridge is indeed running. How do I do this?
Solution:
To verify that the AM Agent Bridge is running, open the Windows Task Manager and check the Processes tab for two processes: amLrss.exe and amss.exe. If these are listed, the AM Agent Bridge is enabled and running.
As for the SD Agent Bridge, which is fully integrated with the software delivery scalability server, if the software delivery scalability server is running, SD Agent Bridge is running.
