Previous Topic: Asset Collection from Floppy DrivesNext Topic: Unprocessed Files
Collect from Network Drives
Symptom:
I cannot collect from network drives.
Solution:
By default the asset collector runs as the Local System account user. You will not have access to the network drives of your computer. You have to configure the Asset collector CAF plugin to run as a different user.
To enable the Asset Collector to collect from network drives
  1. Configure the AssetCollector to allow running as a different user.
    caf setprop assetcollector setcreds 1
  2. Specify the credentials to use.
    caf setcreds assetcollector user <username> password <password>
  3. Stop and start asset collector to start using new user.
    caf stop assetcollector
    caf start assetcollector
To reverse this configuration, use the following command:
caf setcreds assetcollector user “” password “”
