Previous Topic: DifferencingNext Topic: Schema Changes for Origin and Trust Level
Origin and Trust Level are new fields introduced with the Asset Collector. You use them to define the source and trustworthiness of an asset. You can define these fields in the inventory file or within the Asset Collector's configuration and then view the new columns in the GUI.
Origin
Defines the source from which the asset\user is collected and the information is displayed in the DSM Explorer. The source can be a CA ITCM agent or an Asset Collector. For the Asset Collector, you can specify the origin of a collected asset\user either in the inventory file, or in the Asset Collector configuration policy. Typical values for origin can be User Keyed, SMS Extract, and Legacy. Assets collected by the CA ITCM agents have the origin as CA.
Trust Level
Defines the trustworthiness of an asset\user and displays the information in the DSM Explorer. Trust level is displayed as a range of 1 to 5 stars, 5 being the most trustworthy. For Asset Collector, you can configure the trust level in the inventory file or in the Asset Collector configuration policy. As the inventory information collected by the Asset Collector is initiated by a manual process, the reliability of the information may be low. Consequently, the information collected by the Asset Collector has the trust level of 3 by default. The information collected by the CA ITCM agents has the trust level of 5.
