Previous Topic: Replicating IntellisigsNext Topic: Additional Information on Intellisigs
DMScript Extensions
Creating Software Definitions and Detection Records
When you create custom Intellisigs, call the DMScript functions within your Intellisig script for reporting software records that are detected on the agent computer. DMScript provides built-in functions that write detected software records to an output file.
Note: DMScript is a scripting language that provides a common means of executing commands on agents. For more information about DMScript, see the Desktop Management Scripting Language guide in the CA IT Client Manager bookshelf.
The Intellisig script must call the functions in the following order:
  1. OpenDetectedSoftwareOutputFiles
  2. CreateDetectedSoftwareProduct
  3. CreateDetectedSoftwareRelease
  4. CreateDetectedSoftwarePatch
  5. CreateDetectedSoftwareReleaseInstance
  6. CloseDetectedSoftwareOutputFiles
For more information about Intellisigs functions, see Desktop Management Scripting Language guide.
Hierarchy of Intellisig Objects
Understanding the hierarchy of Intellisig objects is important when you create custom Intellisigs. The objects must exist in a particular hierarchy. Each object has a parent, which must be created beforehand. The hierarchy is as follows:
Diagram showing Intellisig hierarchy
Fixed and Variable Parameters
The functions for creating detected software output files provide a way for future extensions by accepting fixed parameters and variable parameters. While fixed parameters are mandatory, variable parameters are optional. Variable parameters typically include the properties that are associated with the Intellisig and provide a means for adding additional properties. The functions can be expanded in future to add variable parameters without impacting existing scripts.
The following guidelines are applicable for specifying and using fixed and variable parameters:
Supported Architectures
Following is the list of architecture names that you can pass to the DMscript functions that write the detected records to the software detection output file:
Error Codes and Optional Properties
The LogDetectedSoftwareError method accepts the error messages in a specific format. The error messages are localizable strings that are generated when there is an Intellisig execution error at the agent. The error messages are then sent to the domain manager and displayed as a status comment against the software inventory collect task in DSM Explorer.
Example: LogDetectedSoftwareError
LogDetectedSoftwareError("ISE:00400","PARAM5=Microsoft Windows 7 Ultimate x64 64 en-us|PARAM6=VersionNumber=6.1.7600 |VersionLabel=6.1.7600 |Language=en-us |Bitness=64 |Architecture=x64 |Manufacturer=Microsoft Corporation|Category=Operating Systems |Description=The Microsoft Windows 7 Product|PARAM7=SWDETECT_BADARGS");
The Intellisig scanner automatically raises the following error messages to report issues related to launching an Intellisig:
Error Code
Error Text
ISE:00302
The intellisig named %1$t, version %2$t, UUID %3$t, is missing the mandatory parameter %4$t.
ISE:00303
Intellisig named %1$t, version %2$t, UUID %3$t, script file %4$t did not produce an output file.
ISE:00304
The execution of Intellisig named %1$t, version %2$t, UUID %3$t, script file %4$t has exceeded the allowable timeout (%5$t seconds).
ISE:00305
Intellisig named %1$t, version %2$t, UUID %3$t, script file %4$t could not be found.
ISE:00306
Intellisig named %1$t, version %2$t, uuid %3$t, script file %4$t, caused an internal error while attempting to start an intellisig
ISE:00307
The dmscript intepreter reported an error parsing the Intellisig named %1$t, version %2$t, uuid %3$t, script file %4$t
ISE:00405
Intellisig %1$t version %2$t, UUID %3$t, script %4$t, %5$t was called to create "%6$t" with an unknown parent "%7$t".
ISE:00406
Intellisig %1$t version %2$t, UUID %3$t, script %4$t, %5$t was called to create "%6$t" with a parent "%7$t" of the wrong type.
ISE:00407
Intellisig %1$t version %2$t, UUID %3$t, script %4$t, %5$t was called to create an instance with a parent "%6$t"of the wrong type.
ISE:00411
Intellisig %1$t version %2$t, UUID %3$t, script %4$t, %5$t was called with mandatory property "%6$t" set to blank.
ISE:00412
Intellisig %1$t version %2$t, UUID %3$t, script %4$t, the lastaccessed property was specified with an invalid value: %5$t: should be in the format: yyyy-mm-dd:hh:mm.
You can raise the following error messages to handle issues related to creating an Intellisig:
Error Code
Error Text
Function Syntax
ISE:00400
Intellisig %1$t version %2$t, UUID %3$t, script %4$t, Failed to create software product. The parameters were ProductName:%5$t OptionalProperties : %6$t. Return Code : %7$t
LogDetectedSoftwareError ("ISE:00400", "PARAM5=ProductName|PARAM6=OptionalProperties|PARAM7=ReturnCode")
ISE:00401
Intellisig %1$t version %2$t, UUID %1$t, script %4$t, Failed to create Software Release. The parameters were ProducName:%5$t ReleaseNameProductRelease:%6$t OptionalProperties %7$t. Return Code : %8$t
LogDetectedSoftwareError ("ISE:00401", "PARAM5=ProductName|PARAM6=ReleaseName|PARAM7=OptionalProperties|PARAM8=ReturnCode")
ISE:00402
Intellisig %1$t version %2$t, UUID %3$t, script %4$t, Failed to create Software Patch. The parameters were ReleaseName:%5$t PatchName:%6$t OptionalProperties %7$t. Return Code: %8$t
LogDetectedSoftwareError ("ISE:00402", "PARAM5=
ReleaseName|PARAM6=PatchName|PARAM7=OptionalProperties|PARAM8=ReturnCode")
ISE:00403
Intellisig %1$t version %2$t, UUID %3$t, script %4$t, Failed to create Software Instance. The parameters were PatchName:%5$t OptionalProperties: %6$t. Return Code : %7$t
LogDetectedSoftwareError ("ISE:00403", "PARAM5=
PatchName|PARAM6=OptionalProperties|PARAM7=ReturnCode")
ISE:00404
Intellisig %1$t version %2$t, UUID %3$t, script %4$t, produced the following error : %5$t
Note: You can specify any custom error text in PARAM5.
LogDetectedSoftwareError ("ISE:00404", "PARAM5="An unexpected error has occured")
