You must modify certain firewall settings on FDCC-compliant Windows XP and Windows 7 computers to ensure that CA ITCM functions properly.
The internal communications mechanisms of the CA ITCM product use the ports described here. CA ITCM cannot operate unless these ports can be accessed. Without access agents are unable to contact their manager or report inventory or status. Also, control messages cannot be passed from the manager to the agent. Communications over these ports is securely encrypted and managed by the CA ITCM product; CA ITCM Release 12.8 uses FIPS-compliant encryption.
Typically, the FDCC inventory detection modules do not require further configuration, other than the configuration to collect test result files. The XCCDF and OVAL test result files are stored in a subdirectory under the Asset Management agent's working directory. To collect these files after the scan and store them centrally in the domain manager, configure the DCS inventory detection modules to enable the automatic collection of the result files.
Note: To configure other parameters in the inventory detection module, see the description of each parameter in the Creating Inventory Detection Modules for Additional Checklists section.
To configure the collection of test result files
The new DCS inventory detection modules appear with the other inventory detection modules.
The Properties for Module Name dialog appears.
The SCAP Configuration dialog appears with the default configuration.
Note: The OVAL test result files are often around 10MB. If you do not have specific reasons for storing them on the domain manager, you can collect only the XCCDF result files.
When the collect task runs again, the engine collects the test result files and stores it on the domain manager.
Note: The result files are signed with a digital signature to prevent data tampering between the agent and the manager. If the manager is unable to verify the signature, an event is raised and logged in the default event log.
When you configure the collection of SCAP result files from the agent, the result files are, by default, stored under the ITCM_installpath\SCAP_Result_Files directory in the domain manager. You can modify the result file location if necessary.
To modify the result file location, change the configuration policy setting SCAP Result File Location under Default Computer Policy, DSM, Manager, Asset Management. When the collect task runs next time, the engine will collect the test result files and store them in the directory specified.
