Previous Topic: CA Message Queuing (CAM)Next Topic: Implementation
Comstore.xml
The comstore.xml file stores all the configuration data for all the CA ITCM components. Each agent has a copy of this file with its own configuration data after installation.
You can modify these configurations using the common configuration policy settings. After any updates, comstore.xml is converted to comstore.enc. Subsequent CCNF operations update comstore.enc only.
To decrypt the comstore, use the following commend:
ccnfcmda -cmd GetConfigStore -fi filename.xml
Important! Entering incorrect values in the comstore.xml will have adverse impact on the functioning of the CA ITCM components.
