Configuring Asset Management › Custom Software Signatures › How to Create Custom Software Signatures › Create a Patch
Create a Patch
If you want to track the patch-level inventory data, you need to create the patches.
To create a new patch
- Navigate to the Domain, Software, Definitions, Categories folder in the DSM Explorer.
The existing categories in the domain appear.
- Select an existing category or create a new one by clicking New Category in the Tasks section.
The existing definitions in the category appear.
- Double-click the product.
The existing releases and suites in the product are displayed.
- Right-click a release to which you want to add the patch and select New Patch.
The Create New Patch dialog appears.
- Specify the details of a new patch in the General, Recognition, and Exclude Options tabs and click OK.
A new patch is created under the release.
More information:
