Architecture › Agent › Agent Working Directory
On Windows computers, the agent's working directory is available in the following paths:
- ...\Agent\units\00000001 folder has the data collected by the agent with the Local System Account.
- ...\Agent\units\00000003 and all the folders with odd numbers have the data collected by the agent from a user's login. Asset management creates a folder for each user on the computer.
- ...\Agent\units\00000002 and all the folders with even numbers are used by software delivery
On Linux and UNIX computers, the agent's working directory is typically available in /opt/CA/DSM/Agent/AM/data/transfer folder. However, the install path may be customized.
