The asset management agent collects the configuration files from the asset if the files were modified since the agent's last run, and records it as a revision in the DSM Explorer. You can push-back any of the revisions to revert to the previous versions.
To view configuration file backup versions
The right pane displays the files configured for backup.
The right pane displays the backup revisions available for the file. Revision number 1 indicates the current version of the file.
The Edit contents to push back to Agent window appears where you can modify the contents if necessary.
The selected revision is pushed to the asset.
