Previous Topic: Planning the InstallationNext Topic: Number of Scalability Servers
Selecting the Best Possible Main Site
The optimum choice for the main site in a large organization is the site where most of your DSM Explorer users will be placed. The domain database should reside at this location.
Select a site where most support and management activities will be carried out. Frequently, this is also the site with most of the asset management agents. The reason for this recommendation is that most database access takes place from the DSM Explorer to the domain database and from the engines to the domain database. (The engines are usually placed in a room designed for technical equipment, and close to the IS department.)
