You can import a saved query and execute it in the DSM Explorer. You must save the query in a .cmsobj file. To import a query definition, navigate to the Queries folder, right-click the folder and select Import Definition.
To export a query created in the DSM Explorer to a .cmsobj file, navigate to the Queries folder and right-click the query you want to export and select Export Definition.
Note: Exporting queries in .qry format is not a valid option in CA ITCM r12.5 and above. However, importing query definitions in the old .qry format is still supported. One way to convert from .qry to .cmsobj format is to import queries in the old format and export them in .cmsobj format. A batch script would be useful if you have many query definitions to convert.
