Previous Topic: Secure Configuration Files JobNext Topic: Scheduling Jobs
Change Job Execution Order
Jobs are executed in the same order in which it was created. However, you can change this order if the execution of one job depends on the execution of another.
Note: You can do this only at the group and asset level.
To change the job execution order
  1. Navigate to the Asset Jobs folder.
  2. Right-click the job for which you want to change the order and select Reorder.
    A sub menu appears.
  3. Select any of the following menu items:
    Move Up
    Moves the job one level up. If you want to move ahead more than one job, click this menu item till you reach the position.
    Move Down
    Moves the job one level down. If you want to move down more than one job, click this menu item till you reach the position.
    Move First
    Moves the job to the first position.
    Most Last
    Moves the job to the last position.
    Set Position
    Moves the job to the specified position. You can use this option for example, when you want to move ahead or below of more than 5 jobs.
    Clear Job Order
    Clears the existing order of the jobs and reorders them alphabetically.
    The jobs are reordered based on the selected menu item.
