By default, the detection modules define the executables from which the inventory information must be collected. If you have any source for collecting such inventory, you can modify the executable file name associated with a detection module. You can also launch the configuration tool to collect additional inventory information and specify the platforms on which the module is supposed to run.
To view or modify an inventory detection module, double-click the module. The Properties for Detection Module dialog appears. Modify the settings in this dialog as you require.
Note: For more details about this dialog, see the DSM Explorer Help.
