Previous Topic: Create, Configure, and Schedule Software Discovery Collect TaskNext Topic: View the Discovered Software
Export Discovered Software Information
The Discovered Software report displays additional details such as the installation path and the number of installations. You can export this report to a csv file and save it in your hard disk.
To view and export the discovered software information
  1. Navigate to the Discovered folder in the DSM Explorer.
    The discovered software are displayed in the right pane. This information is available only if the software inventory collect task runs successfully.
  2. Select the discovered software for which you want to view the report and right-click the selection.
    The context menu appears.
  3. Click Details.
    The Software Report for Computer dialog appears.
  4. Click Export.
  5. Specify the csv file name and path in the Enter output file dialog and click OK.
    The report is exported to a csv file.
More information:
Check the Status of a Collect Task
