The following is a .MIF file example:
Start Component
// A double slash indicates that the line contains comments,
// and should be ignored...
// First we name and describe the component...
Name = "AM Windows 95 PC information"
Description = "This MIF file contains basic hardware inventory for a AM Windows 95 Computer"
// Then we list the groups...
Start Group
// First we name the group....
// Every group within the component must be
// assigned a unique ID and a class...
// and optionally a description
Name = "Processors"
Id = 1
Class = "AM|Processors|001"
Description = "Describes the processors present in the system"
// Then we list the groups attributes...
Start Attribute
// First we name the attribute....
// Every attribute within the group must be
// assigned a unique ID and optionally a description
Name = "Main processor type"
Id = 1
Description = "The type of processor currently in the system"
// Specify the attribute type (A string)...
Type = String(64)
// ...and the attribute value...
Value = "Pentium"
// End of attribute...
End Attribute
// Describe a new attribute within the group...
Start Attribute
Name = "Main processor speed"
Id = 2
Description = "Maximum speed (in MHz) of this processor"
Type = Integer
Value = 90
End Attribute
Start Attribute
Name = "Main processor vendor ID"
Id = 3
Description = "This is the Vendor ID returned by the processor in response to the CPUID instruction"
Type = String(64)
Value = "GenuineIntel"
End Attribute
// Continue until no more attributes in the group...
// End of group...
End Group
// Describe a new group within the component...
Start Group
Name = "Operating system"
Id = 2
Class = "AM|OSsystem|001"
Description = "Describes the operating system running on this system"
Start Attribute
Id = 1
Description = "Specifies the operating system"
Type = String(64)
Value = "Windows 95"
End Attribute
Start Attribute
Name = "Operating system Major version"
Id = 2
Description = "Specifies the major version of the operating system"
Type = Integer
Value = 4
End Attribute
Start Attribute
Name = "Operating system Minor version"
Id = 3
Description = "Specifies the minor version of the operating system"
Type = Integer
Value = 0
End Attribute
End Group
// Continue until no more groups in component..
// End of Component...
End Component
