The CPSA process is summarized below and in the following flow chart.
First, the CPSA checks which application the user is using. If this is:
Data In Motion triggers activate when the CPSA detects print jobs that match the specified criteria. For example, you can set up triggers to monitor (or exempt) specific printers on your network. You identify printers by their name, for example, 'HP Color LaserJet 4650 PCL 6 1st Floor'.
When a file is sent to a printer, triggers can detect specific file names and file formats (such as Microsoft Word documents). They can analyze the text content to detect the key phrases or to check whether the file matches a particular document classification. They can also use XML Attribute data lookup commands to file attributes such as size, date created, date last modified, and the file author.
Finally, you can configure triggers to block or allow the print job or to display a warning.
