Previous Topic: Set Global Sections and Global PagesNext Topic: Execute AUTOGEN and Reboot
Accommodate High-Data Rates
To accommodate high-data rates from the consoles managed by Console Manager when LAT and Direct connections are used, it is necessary to increase the size of the alternate type-ahead buffer and the XOFF threshold for the alternate type-ahead buffer. Add the following two lines to SYS$SYSTEM:MODPARAMS.DAT:
Note: The above two parameters may be increased, but the 3-to-1 ratio should be maintained.
