Specifies the name of the system from which the event originates.
Specifies the name of the event.
Specifies the class of the event.
Specifies information describing the event.
Specifies the condition causing the event.
Specifies the time of the event.
Specifies the priority. This is one of the priority codes as defined in <console.h>.
Specifies the subsystem on which this event has occurred.
Specifies the source of the event, which is typically the name of the detector of the event.
Copyright © 2010 CA.
