Specifies the Console Manager context. This value should be the same as the one returned from a previous call to CMUserInit or CMUserPPInit. If no previous call to either of these two routines was made, then a context block will be created, initialized and returned to you upon successful completion of this routine.
An event that has been received from ENS.
A NULL terminated string describing the person or application which has performed the acknowledge.
Copyright © 2010 CA.
