Specifies the address of the event structure for which the data specified by Xxxx is to be returned.
CMEventXxxx routines Enter specific details about the event they are passed. Most of these routines are macros and you should use them as the preferred mechanism for accessing the internal structure of an event. This mechanism provides protection if the event structure changes in future releases.
The following table shows the valid values for CMEventXxxx routines.
Xxxx Value |
Enter Type |
Returns |
Name |
char * |
The name of the event as stored in the Console Manager database. |
Class |
char * |
The class of the event as stored in the Console Manager database. |
Info |
char * |
The information for the event as stored in the Console Manager database. |
Text |
char * |
The line of console output which activated the event. |
Context |
int |
The full context for the event as logged in the host's log file, and count of the lines retrieved, -1 on error. Obtain the context data using the CMEventContextYyyy routines. |
Time |
time_t |
The time at which the event occurred. |
Type |
int |
The type of event, one of CMEventTypeEvent, |
Logtime |
time_t |
The timestamp of the event in the log file for the host on which the event occurred. |
Count |
int |
The number of context lines for the event as stored in the Console Manager database. |
Priority |
int |
The priority of the event as stored in the Console Manager database. |
Source |
char * |
The source of the event, which is typically the name of the detector of the event. |
Start |
int |
The start line of the event relative to the line on which the event occurred as stored in the Console Manager database. |
SubSystem |
char * |
The subsystem for the event as stored in the database. |
Host |
char * |
The hostname of the system on which the event occurred. |
System |
char * |
Userdata |
char * |
The userdata value from the dispatch record which caused this event to arrive at the action. |
Returned values should not be freed by the caller. They are freed by a call to CMFreeEvent().
Copyright © 2010 CA.
