Archive cleanup is a command procedure. If there are any files older than 24 hours on the system, they are automatically deleted. If there are no files to match this criteria, all files are deleted.
If you want some other action to be performed instead of deleting the files, you can edit the shell script or command procedure to perform whatever tasks are necessary to free space in the archive directory, such as backing up the files to tape before removing them.
Copyright © 2010 CA.
