You must specify values for the following items, otherwise the action will fail:
Value |
Description |
HOST |
The DECwindows display you wish the window to appear on. |
SERVER_NUM |
The number of the server on the HOST display, normally 0. |
SCREEN_NUM |
The screen on which the window should appear. For single head workstations this is 0 and for dual head workstations it may be 0 or 1. |
TRANSPORT |
The DECwindows transport which your DECwindows client and server support. This routine supports TCP/IP, DECnet and LAT transports. |
For example:
SALT 0 1 TCPIP
This places the Eventlist window on the system SALT, X-Server 0, screen 1, using TCP/IP as the transport.
Copyright © 2010 CA.
