Previous Topic: Connect to the Console of a Serviced SystemNext Topic: Entering the Monitor Interface
Exiting the Console of a Serviced System
To exit from the console of the serviced system to which you are connected, press the control sequence you have defined for the Exit key (the default is CTRL_E).
