Previous Topic: Serviced Systems You Can Monitor and ManageNext Topic: Parent Console Controller
Management and Monitoring Tasks
When you connect to a serviced system, your workstation or terminal acts as the console of that system, and from it, you can perform any management tasks you can normally perform from the local console, such as the following:
You are not limited by the operating system you are running.
Console Manager lets you monitor console activity and do the following:
Information about serviced systems must be stored in the configuration database; otherwise, you will not be able to access them. The configuration database is discussed in Chapter 4, “Modifying the Configuration Database.”
