Previous Topic: How IPX Discovery WorksNext Topic: How Discovery Uses Subnets
How SAN Discovery Works
SAN Discovery locates SAN fabric devices (fiber-enabled switches, bridges, and hubs) and SCSI devices connected to the SAN fabric. It also creates Business Process Views in the WorldView 2D Map of the SAN fabric and the links between the objects.
Note: SAN Discovery is available in CA NSM and some other CA solutions. However, discovery of SAN hosts has been disabled in CA NSM.
After the initial SAN Discovery is run, you can rerun SAN Discovery manually using any of the following methods:
Discover SAN Devices Only
Executes an IP Discovery on the subnets you specify and only SAN devices are added to the MDB.
Once the device discovery is complete, SAN links are determined. SAN Discovery uses the newly discovered SAN objects as well as any already existing in the MDB to determine the SAN configurations within the subnets that were searched. The SAN configurations can be composed of IP and non‑IP (SCSI) enabled devices.
Typical IP Discovery
Executes an IP Discovery on the subnets you specify. The SAN devices are discovered and identified during the Discovery process.
No IP Discovery - Refresh SAN Links only
Re-determines the links of previously discovered SAN components in the subnets you specify. IP Discovery is bypassed and SAN Discovery uses only those objects already present in the MDB to determine the SAN configurations in the specified subnets.
