To use the Unicenter Support for DMI functionality, you must install the DMI Agent and the DMI Manager. You can install these components from the CA NSM installation DVD. Install the DMI Manager on a computer that will be used to monitor remote computers; install the DMI Agent on each computer that you want to monitor remotely.
To install the DMI Agent and the DMI Manager on Windows platforms
The installation program starts automatically, and the Unicenter Product Explorer window appears. The option for Installation Wizard for CA NSM is preselected.
The CA NSM Installation Wizard window appears.
The Component Selection window appears.
Click Next and continue with the installation. For more information about installation, see the Implementation Guide.
Copyright © 2010 CA.
