UNIX/Linux platform Security Management options are located in the $CAIGLBL0000/secopts file. You can use the editor of your choice to modify the option settings in this file.
If you are upgrading to CA NSM from an earlier version, you may consider refreshing the $CAIGLBL0000/secopts file with the new version, $CAIGLBL0000/secu/scripts/secopts, so that options can be located by Security Management.
Copyright © 2010 CA.
