Previous Topic: Status of SCOM Entities in WorldViewNext Topic: Scanning the Systems for Viruses
SCOMMsgconfig Utility
The SCOMMsgconfig utility lets you select the SCOM alert fields to be included in the corresponding CA NSM EM message from the CA Unicenter System Center Operation Manager integration. You can select any SCOM alert field in the EM message and in any order.
Configure SCOMMsgconfig Utility
By using the SCOMMsgconfig utility, you can select any SCOM alert field that you want in the EM message.
To configure SCOMM utility, do the following:
  1. Go to the CCS\WVEM\OpsMgr folder
  2. Run the SCOMMsgconfig.exe command from the command prompt.
    The Message setup for NSM SCOM Integration window opens.
  3. From the SCOM Alert Fields drop-down list, select the fields to be included inside the message to EM. You can select multiple fields. Selected fields are sent to EM in the order selected.
  4. Click Add to add the SCOM alerts to the "Fields to be included inside EM message" text box.
  5. Select the OpsSeverName check box to send the SCOM server name inside the message.
  6. Select the Enable check box to enable all SCOM configuration you have set up in the above steps.
    Important! You must select the Enable check box to enable all SCOM configuration otherwise the changes will only be saved and not be enabled.
  7. Click OK and restart CA Unicenter SCOM service to enable the new SCOM configuration.
In CA NSM r11.2 or CA NSM r11.2 SP1, the Node field contained SCOM server machine and the Workstation field contained the SCOM alert originator name. However, in CA NSM r11.2 SP2, the Node and the Workstation field contains the SCOM alert originator name.
