Building a Sample PIF Product › Localize the Installation Dialogs for the PIF Product MERCHANT › Localize the Installation Dialogs Through the GUI
You can localize the installation dialogs through the GUI.
To create localized text strings for the installation dialogs
- Run the smgui command to launch the Packager GUI.
- Select the PIF product MERCHANT in the project pane.
- Select and right-click the English/US entry on the Dialog resources tab in the subproject pane.
- Right-click the selected resource and select Copy from the context menu.
The Product resource dialog appears.
- Choose the desired language German from the drop-down menu.
- Click Copy.
The German language entry appears on the Dialog resources tab in the subproject pane.
To translate the texts in the German dialog resource proceed as follows:
- Select the German language entry on the Dialog resources tab.
- Double-click a text in the Dialog texts table and type the German translation of the text directly into that line. Perform this step for each text string to translate.
