Previous Topic: Configure the Encryption Method for a PIF PackageNext Topic: Delete a PIF Package
Unload a PIF Package
You can unload (remove) a PIF package from the project pane, but the package is not removed from the disk. The package is still contained in the product library (productlib), from where you can import it again. You can unload one or more packages at the same time.
To unload a PIF package
  1. Select the packages in the project pane.
  2. Right-click a selected package and choose Unload from the context menu.
    A dialog box appears asking you if you really want to unload the selected package.
  3. Click Yes.
    The selected package is removed from the project pane.
