Previous Topic: Register a PIF Package to Library or to DiskNext Topic: Configure the Encryption Method for a PIF Package
Modify a PIF Package
You can modify a package to make any updates after you create the package. You do not need to create a new package to incorporate changes at a later stage like adding a new element to the existing dialog. This also allows you to keep the package up-to-date.
The following example explains how to modify an already created package by adding a new element to a dialog:
To add a new element to an already existing dialog
  1. Select a package from the Project pane.
  2. Select the Dialogs tab from the subprojects pane.
    A list of all the dialogs included in the package appears.
  3. Select the dialog in which you want to add a new element.
    The dialog (including already existing elements) appears in the right pane.
  4. Select a new element from the dialog editor's toolbar and drop it at the appropriate place in the dialog.
    The new element is added to the already existing dialog and the package is modified.
