After completing the settings for the PIF package and saving it, you must build the PIF package.
To build a PIF package
The Build package dialog appears.
If this check box is checked, indicates that a self-installing PIF package (including the Installer) is automatically built. A drop-down list opens and lets you choose the package platform. The following options appear:
If this check box is checked, indicates that all symbolic information is removed from all binary files of the PIF package. This will reduce the size of the PIF package.
If the package already exists, indicates that this check box appears on the dialog. This box is checked by default, that is, the existing PIF package with the same name is overwritten.
The Save in dialog appears where you can specify the location to store the PIF package. By default, the PIF package is stored in a directory referenced by $SDPcker/productlib.
After the PIF package has been successfully built, the Media tab contains a corresponding product entry.
