Symptom:
I want to install the Packager for Linux and UNIX on a computer that has no DVD drive. How must I proceed?
Solution:
If you want to install either the Packager for Linux and UNIX or the Command Line Interface (required to register a package from Linux or UNIX to a manager on Windows), you must download the Packager directory structure (using FTP or SFTP, for example). Then run install-sm-packager.sh from the directory on the Linux computer that contains the whole downloaded Packager directory.
Valid on SuSE 11 only
Symptom:
During a package installation, configuration, or uninstallation procedures, the following warning message appears:
Solution:
Disregard the warning; it has no impact on the installation, configuration, or uninstallation procedures.
Valid on SLED11SP3X64 only
Symptom:
While creating self installing PIF Package, SM Packager displays the following error message:
Solution:
This happens if the Midnight Commander software is installed on your computer. Uninstall the Midnight Commander software and continue with creating the self installing PIF Package.
